Vintage Air Backlighting.....
broncoitis
Don't know about the rest of you on here but it seems that alot of us are using the Vintage Air setup in our trucks for the A/C and Heat in our trucks. Now depending on which control panel you choose, the backlighting is absolutely USELESS. Being a tinkerer, the lighting that Vintage Air had designed into the system was not gonna cut it for me!
Don't get too distracted by the glow in the back of the modified panel because once it is mounted in the dash that is all hidden. The cool thing about this upgrade in the lighting to LEDs is the fact that the amount of light is adjustable with the headlight dimmer switch and I didn't think this would be possible with the LED's!
I will post more pics of how I did this if anyone else is interested. If you can solder and use scissors then this mod is pretty simple with a HUGE upgrade in the backlighting so you can actually adjust the levers with the lights out in your truck!
Total cost of upgrade is probably about $15 - $20 bucks! ;D
broncoitis
broncoitis
Oh yeah, for me cost was a bit of a factor in choosing this control panel but I also like the look of it a bit better compared to the other control panel. I will post some more pics of what I did in the coming days.
Justafordguy
Looks good, I bet you don't have any trouble seeing that thing now.;D The controls that came with mine have no lights at all so I have to turn on the interior light to see.
broncoitis
broncoitis
That Picture is really not a good indication of what it actually looks like in the truck lit up! It doesn't have that glowing effect in the back at all. That is just a pic of the gutted panel with none of the levers installed on the back so alot of the blue light is reflected back out. Personally, I like a nicely laid out dash and that OEM Lighting was horrible to me. No problem seeing it now though! ;D
I don't know how many others are running this type of control panel but I am gonna post what I did and if anybody wants to give it a shot, it is totally worth it in my eyes!
Here is a pic of the panel installed and lit up in the truck.
Tito
CB Fire Starter
Bakersfield, CA
Nice. I have the cobalt gauges too, they are almost too bright for me. Are you using the AC kit from BC or from a VA dealer?
getfuzzy
Looks good. I can't make up my mind witch a/c to get BCB or ? I'll be reading alot before spring comes and I do the install. Is yours for BCB or someone else.
broncoitis
broncoitis
I haven't hooked up the guts of the system yet but I decided to go with an off the shelf unit from Vintage Air!
Gen II Compac Unit. I didn't go with the BCB unit! hopefully I didn't make a huge mistake. :eek: I think that it will work out the same but the routing will obviously be a bit different than the BCB design. So long as I can get the Gen II to fit behind the dash and hook up the vents and defrost ducts it should not be a problem. The rest I can figure out. :cool: At least I hope so. LOL
kc15842
Lake Elsinore, Ca
I have the vintage air system, as I am now finishing the build maybe it's time to pull it out of the box. You peaked my interest so I pulled out all of the boxes. It just looks like a bear for the install. How was it? Any lessons learned?
broncoitis
broncoitis
Have not actually started the install yet! Gonna get going on it soon though. Not really particularly worried yet but I have completely change the location of alot of things on my dash and space under there is tight to begin with. My plan of attack is gonna be to first make a cardboard box the exact dimensions of the blower unit for easy handling with the dash still mounted and go from there. Only thing that might hold me back right now is that the space I am working in is tight and it is getting COLD! :( I will post picks as I go though! Gonna be fun I think either way because I like a challenge and my dash has thrown me a couple of curve balls already so what could possibly be left? ;D:eek:
englewoodcowboy
Lick Creek Restorations
If you call Vintage Air, they have mock up boxes. I am doing my system but peicing it together through V/A. The box they have for the EB is OK for most but if you live in a hot humid climate, it is not big enough or if you plan to run a soft top, it will struggle. I am going with a larger system which will require notching the center hump (Just like Nick does on his rigs) and I am flatening out the passenger cowl to gain some more space and a better finished look. I am also seriously thinking about the dakota digital control for V/A.. I just have to decide if they are worth the money but apparently they do add some more options to the system....
broncoitis
broncoitis
That Dakota Digital Panel is pretty sweet I would have to agree with you on that! Pretty EXPENSIVE THOUGH! :eek: Hadn't thought about notching the tranny hump / bellhoushing area. As for the cowl on the passenger side, I guess depending on the size of the unit you go with you may or may not have to play with that as well. Gonna look at Nick's site to see what he did if there are any picks on there. Ideally, I would like to center the floor heating vents evenly over the tranny hump in order to evenly distribute the air in the footwells on the driver and passenger side! Who wants cold feet? ;D
I think that the Gen II Compact is gonna work out nice! Actually getting psyched about this install. Gonna be fun and frustrating all at once. ?:?
broncoitis
broncoitis
englewoodcowboy,
Ok, maybe you gotta be a part of his top secret page to see these mods to the cowl and tranny/firewall notching but I checked ALL the threads and did not see any clues of the mods. :( However, their workmanship looks top notch and really nice. Wish I had the green to have one done by them! :( Ahh, that is allright though kinda like doing stuff myself anyway. ;D
Anyway, I am gonna get going on this because I don't see any reason right now why the blower unit under the dash cannot be mounted closer to the center of the bronco instead of all the way to the right against the passenger kick panel? We will see though, gonna measure twice and cut once. ;D Now, if NJ could only get a bit warmer. :(
englewoodcowboy
You only get access to his top secret if he is building a bronco for you. Here is a pic of the hump he has modified:
These are pics of the Atlanta Build:
And unit installed:
NY-Bronco
Resident Dipstick
Weehawken, NJ
I have the BCB version. The big difference between their version and the vintage air version is how the condenser gets routed to the dryer and to the evaporator. Definitely better.
I just got everything mounted under the dash and connected everything and Im quite happy with it.
The switch I went with this one:
Its simple and takes up no space and the backlight matches the speedo cluster I got from them.
NY-Bronco
Resident Dipstick
Weehawken, NJ
Yeah!! THE INSTRUCTIONS SUCK!!!! BIG TIME!!!
englewoodcowboy
I would like to go with BCB's version for fitment but I am just leary if it will be enough.. You will have to let me know how it does this summer if you don't mind. I want to make sure it will cool with the softop on, I dont live in FL so it may be ok for me too...
kc15842
Lake Elsinore, Ca
Your right, after I read this thread I un-boxed everything. My blower motor sucks so I thought maybe this is a good time. I read everything and found very little specific info related to a Bronco install. I must have lost something.
broncoitis
broncoitis
Nice job NY! See, there was a little mechanic hidden in there! You just had to find him! ;D ;)
broncoitis
broncoitis
Ok, have to take a look at that thread again! However, if I go any direction with that area of the firewall, it will be going forward and not further back. Can't see what the benefit would be to come back.
For all the others, on the directions I think that the reason is that there not specific to any vehicle. Basically, all they are saying is this is where it goes generally now you figure out how to put it there where you want. :(
BCB in terms of bronco specific is the way to go if you don't like to play with things and the instructions are pretty good after I looked them over from their posted adobe files! Definitely a nice setup!
However, I think that the Gen II Compac unit will work out just as well and I think that I can get it into a more central location in the truck! Just bear with me and the photos will be coming because this is gonna get done sooner than later even with the balmy NJ weather right now! ;D
And unit installed:
