LowCountryEB
Ok. I have changed the battery, alternator, starter, ignition switch and solenoid. My Bronco will crank but will not run. I have volts from the solenoid and coil. I have ran the test. The motor will fire up if I hold the key in the start position but as soon as I let go of the key, it dies. Could this be a voltage regulator problem? What can I try next? I am a newbie to this electrical stuff but just bought a multi meter over the weekend. How exactly do you use this thing? Can you give me some more advice on how to get my baby running??? Thanks........
