• Be EXTREMELY cautious if someone offers to buy your Bronco for more than your asking price and sight unseen. ESPECIALLY if the buyer is overseas. It's probably a scam.
    Discuss it more here:
    http://classicbroncos.com/forums/showthread.php?p=514932
Wanted EB D44 knuckles
Status
Not open for further replies.
Jerrod4567
Bakersfield CA
I have a High pinion 44 that im cutting down to put in my bronco, however I'd like to keep my GM disk brakes so I will be needing a set of EB knuckles in order to use my brake setup, thanks. I can either buy them outright or I have a set of disk brakes from a 78-79 that I might be willing to trade.
Broncitis
MEB Founder
EB knuckles
I have these parts if you still need them. Original EB drum 44 knuckles and spindles.
Will sell outright or might trade for your 78-79 knuckles, spindles, caliper brackets, hubs depending on the shipping cost.
Let me know if you're interested.
Jerrod4567
Jerrod4567
Bakersfield CA
I'm not sure what the plan is for the brakes on the 78-79 yet, if I end up keeping them, how much would you guys be willing to sell the knuckles for?
Also, does anyone know if swapping EB knuckles to a 78-79 housing is a direct swap?
Broncitis
MEB Founder
Yes, the knuckes are a direct swap, but the location of the tie rod hole and height and offset of the arm on the knucles is different so a different/modified tie rod may be needed.
The 78-79 also uses a larger tapered hole, but you can get a reducer bushing or drill it out and use either Heim type rod end or the Chevy tie rod end type heavy duty systems.
iwlbcnu
I'm running the 78-9 knuckles and Drews linkage on a 74 Bronco 44.
Jerrod4567
Jerrod4567
Bakersfield CA
Hmm... here is a question. I dont have the steering off of an EB 44 but I do have the steering off of my D30. If I use the 66-77 44 knuckles, on my 78-79 housing, will the steering from my 30 bolt up to it? Thanks.
Broncitis
MEB Founder
No, the 78-79 housing will be wider and therefore your tie rod and draglink will be too short.
If you don't mind drilling out the knuckles, I can make you a Heim type rod end system custom fit for your application. We've been making these for 7-8+ years now. If you want the 44 knuckles I have I can drill and ream them for you on the milling machine.
Jerrod4567
Jerrod4567
Bakersfield CA
Im going to cut it down to early bronco length, I know the short side will still be .5" longer than an EB 44. Is that still too much longer to make my 30 linkage work? I'm thinking about the high steer stuff too, just wondering how much work its going to take, I'm looking for cost efficient right now haha. thanks for the info, and I'll let ya know about the knuckles once I decide which route I'm going to go.
scsm76
Shaver Lake, CA
Im going to cut it down to early bronco length, I know the short side will still be .5" longer than an EB 44. Is that still too much longer to make my 30 linkage work? I'm thinking about the high steer stuff you have too, just wondering how much work its going to take, I'm looking for cost efficient right now haha. thanks for the info, and I'll let ya know about the knuckles once I decide which route I'm going to go.
The tie rod for the EB D30 and D44 are interchangeable, so if you run the EB D44 knuckles on the narrowed 78-79 housing your current tie rod should work as long as it can adjust out the 1/2".
Status
