Cooter_76
- May 18, 2004
- 863
I'm mocking-up some new rock sliders from White Knuckle Off Road and WH Gorilla Warflares, and could use some guidance. The rear fenders were cut and flared when I bought the Bronco. Fronts are currently uncut.
First question is about the sliders. My rockers were a bit dinged-up from contact with rocks. I've managed to beat them back into decent shape with a BFH. On both sides, when supporting the sliders with a floor jack, the gap at the bottom of the door is larger at the front vs the back. Not sure if the rockers need more massaging to tuck the front up higher, or if I should lower the rear of the slider until the gap is consistent.
Front Flare: I know these flares are flexible so you can adjust to fit your specific needs. I'm looking for a "traditional" install vs the "extreme" option. If I lay the flare over the fender where it naturally wants to go, it sits about 2" below the crease in the body line. At the rear it overlaps the rock slider. The current rear flares sit about 2.5" below the crease on the driver side and about 3" below on the passenger side.
Visually, does it matter if the front flare is closer to the crease than the rear? Is it fine as long as it's level? Should I trim the slider to accommodate the flare or try to overlap?
Rear Flare: The new rear flares seem to have a larger opening overall. If I match the front edge with the old flare, the rear edge wants to land a couple inches further back.
The current rear flare is right up against the front filler neck, which may limit options for positioning the new flare.
![](https://live.staticflickr.com/65535/51861781631_06c2426d25_z.jpg)
![](https://live.staticflickr.com/65535/51860821557_925121c068_z.jpg)
![](https://live.staticflickr.com/65535/51860821552_83d91f3076_z.jpg)
![](https://live.staticflickr.com/65535/51862436450_f1a501a507_z.jpg)
![](https://live.staticflickr.com/65535/51862436445_1f136b11db_z.jpg)
![](https://live.staticflickr.com/65535/51861863473_cd9c3fabf7_z.jpg)
![](https://live.staticflickr.com/65535/51861863478_4c1d7cc859_z.jpg)
