Warn Full floater with rear discs
BRONKEN
Morgan Hill, Ca
What do you want to know? Buy the brackets from Warn, get the calipers,rotors & hoses from a local auto supply. You will have to open up the rotors abit to fit the flange of the hub, at least thats what I had to do running the 35 spline kit.
Ken
toddz69
broncbusted said:
Warn does not sell the brackets anymore,not enough interest I guess, its a money thing. What calipers did you use?
Are you sure? I still see them listed in my 2006 Warn catalog......
If you want the e-brake option, use 79-85 Cadillac Eldorado calipers. If you don't need an e-brake, ask for front calipers from an '83 Monte Carlo.
Chuck has told me in the past that his brackets work with the FF kits too. Might be a good option and you keep some $$ in the Bronco community that way too.
Todd Z.
SteveL
Huge chevy guy
Hawthorne ca
If chucks brackets fit the FF kit use them. With the warn brackets you have to pull the caliper out to bleed it. PITA. I didn't have to modify my rotors to fit with the 31 spline kit. They are jeep rotors, I think late 80's. I have the paperwork if you need the year. I ended up swithching to the hub flanges because I broke 2 of the rear hubs and they kept leaking out the allen bolts on the cap.
