warn premium manual hub install
nysledge
Greensboro NC
This will probably seem ridiculous to most of you, but does anyone have clear illustrated pictures of how to install replacement hubs? It was time for new shoes and while in there I decided to change the hubs as well. I want to make sure that I get this put back together properly the first time.
Redleg
I just lay the parts on a clean piece of carboard or a rag in the order I take them off, one side at a time, and then re-assemble in order. You can also find shop manuals on line (Ebay) for Broncos from time to time.
SteveL
Huge chevy guy
Hawthorne ca
The premium install is pretty simple. As long as you put the body on the right way it's hard to screw up. There aren't as many parts as the stock hubs.
77broncoguy
Grand Rapids, MI
Just like above said. You can't really get it wrong. If you're replacing the stock hubs, then you don't reuse the spring. Unless you've taken the warn hub apart it basically goes in like a cartridge. If you've disassembled the hub (removed snap ring), it still only goes together one way. You can check out the warn site for a parts drawing I think. You should have two snap rings, one inner and one outer.
admin
Administrator
Just your friendly, neighborhood webmaster...
Phoenix, AZ
If you don't follow the second sentence then the first sentence is false. ;D
The most common way to get it wrong with Warns is to re-install the factory big spring. Many of us have done it only to sheepishly admit years later (and failed hubs later) that we've done it wrong...so don't be like us.:cool:
feitctaj
FNG
Group W Bench
well as usual I can find a away to assemble something wrong%) , AH ER AH back 15 years ago when I installed my premiums I applied too much grease,
"Not so much FEITCTAJ!":mad:
More than just a slight film an You be sorry;)
N
nysledge
Greensboro NC
Thanks to everyone that responded. The hubs seem to have globs of grease in them and I was curious about why the new warns did not come with the large springs. I appreciate everyones help.
