Water pump/timing cover issue
enduro4fun
Stockton, CA
Hey guys. I have a problem that maybe somebody has run into before. I just finished the engine in my wifes bronco a 1969 302. I started to put coolant in the engine and as soon as it got to the level of the water pump it started pouring out of the bottom of the pump. I pulled the water pump back off to see what was going on. I notice the gasket was shaped different on the bottom compared to the timing cover. I took a look at another cover I had and noticed the shape of the pump mounting boss is different. It looks like maybe if I use the same gasket as the one between the pump and backing plate it might work (pictures below). Anybody run into this before?
WATER PUMP
[/IMG]
TIMING COVER ON ENGINE
[/IMG]
SPARE TIMING COVER
[/IMG]
Rox Crusher
I just had this same problem this week end.
The gaskets are different.
The one that goes between the timing cover and the water pump backing plate has to go around the two bolts that fasten the backing plate to the pump housing.
The other gasket doesn't.
E
enduro4fun
Stockton, CA
did you use 2 of the gaskets that go between the pump and backing plate or did you find something else? The funny thing is with that configuration some water is going to bypass the pump inlet between the backing plate and the timing cover, I guess it's not enough to hurt pump efficency
TBS-POPS
valley springs, ca
The timing cover on your engine is an early 260/289 cover and your spare is a later 302 type. The water pumps and gaskets are different. so if you got a wp for a 69 302 it would be wrong. look at the difference with your old one. those two bottom holes in that waterpump with that gasket should have two shott bolts that go in ffom the backside hense the bulges in the gasket and your later cover.
Boss351
Foxboro
just went through the same thing I just cleaned it up and put bead of ultra black around the water holes on the pump and bolted it together no problems but there is 3 different timing covers Check the "d" holes for the water passage and the bottom to divets for the two cover bolts they flip flapped them in the late 80"s and early 90's
E
enduro4fun
Stockton, CA
Ok thanks guys. I got another gasket for the pump to backing plate, and It lines up perfectly for the pump mounting gasket, so I'll bolt it together and give it a try.
