Installed a dana 44 with Chevy disk conversion on my 1970. Used existing mc and the h block. Ground the knuckles, bleed rear first but the rear would squirt a little fluid and stop. Sometimes you could open the bleed screw all the way up or take it out and the peddle would not go to the floor or push fluid out. Front bleed fine, stops ok but will lock the rear before the front.
Why would the fluid not bleed out of the rear even with the bleed screw all the way out? It will bleed fine a pump or so then just stop.
Do I need a diff mc?
How about a prop valve?
