Ohio Bronco 21
This is a new one.
Dads 69 Bronco is overheating and brakes also over heating after about 45 min of running her. Its a 302, headers, 4 core radiator, power brake booster/disk. The engine gets up over 215 after some time, when checking the engine compartment the Brake booster is really hot as is the master cylinder and brake lines somewhat warm, almost boiling the brake fluid in the master. The Engine is really hot too.
The brakes are not hanging up and I checked the booster pushrod to the master cylinder, It was adjusted a little out so I adjusted it in a little. I thought it may of been slightly causing the brakes to rub when the engine was running and vacum up. The longer you ran it the hotter the brakes would get and the lines and finally the booster/master. I thought this would also of caused the engine to overheat due to drag on it.
Well, doing the adjustment on the brake push rod may of helped but He still has the same problem. I checked the lines and while they are somewhat close to the headers they do not touch and the lines themselves are not heated up much.
What could be causing the brake system to heat up so much and the engine also? Thanks for any help or ideas.
