i'm no expert
but my few suggestions are as follows (FYI, i didn't see a welder in that link):
-get a good brand
-think about your needs/wants in the FUTURE: what you will want to use it for? as you become more skilled will you be do more stuff? how thick a metal do you see yourself welding? if your in the market for a small one for use around the home, think about whether you want 110v or 220v? its money better spent IMHO now for the right piece than deciding you got the wrong thing later.
-the biggest piece of advice given to me when i was shopping was to spend the little extra money up front and get a MIG (by that I mean at least a flux-core that is capable of doing MIG).
-for me, i only dick around w/ little projects on trucks and bikes (bumpers and rollbars are about as big a project as I will tackle, and things that need to be water/air tight or really precise i take to someone else (usually TIG'd). i definitely wanted a wire feed, and chose a little lincoln MIG that also does flux core (i only use that shit for making a bird bath for the old lady or stuff like that), welds up to 5/16 or something. can take the 8lb spool. welds aluminum and SS with the right wire. small portable. the whole thing, with regulator.... was like 600 at Lowes. parts/warranty are readily available. gas is seperate, and an 80 cubic foot bottle should be 140 or so (but 40 and 60 are available depending on what your needs are), and a 75/25 co2/argon mix is only like 25 or 30 bucks.
-you'll probably get 40 different opinions on this topic, but, that's my .02. for small limited use, i think the cheapest MIG at the home stores is around 450, including a helmet and some wire. get some gas and gloves and your in business.
