ok,, thanks for the response,,
I think I'll get the makita,, and see if I can find the milwaukee discs and cut off wheels.( making sure it has a 5/8 arbor) I have a larger makita and it seems you can't kill it,, or least thats what my daddy says.
I like the milwaukee grinder but its over $100 and the makita is $59 as I may not use it that much ,, but it will be handy when you do.
I think I'll stay away from air tools,, after I read some more yesterday it would seem you need to go to gasoline power/ large tank to be able to run all the tools sufficiently?
So far I've been getting all my bolts out,, PB blaster , grunt, grunt method,,. but then have mostly been small bolts. I've only wrung one off so far.
I may be back to ask about the impact wrench for larger stuff.
I keep looking for a spot weld bit but can't find one? I have plenty of drills and bits though. ( but not to that point yet.)
