WH Door Insert install
schneire
Lindenhurst
Well I bought the inserts from WH. Unfortunately, being a newbie and all, I didn't get the rockers just right(I think). This leaved me with a problem.
Please HELP....
TexasBronco
Waterford, MI
As with most fiberglass parts they aren't a 100% perfect fit. You may need to do some grinding and sanding to make it work. I have never installed the inserts so I am not real sure how to fix your problem.
hd03sporty
Tucson AZ
Did you replace the rockers??? I have seen these door inserts and they shouldnt be that far off from the hieght of the rear bed rails, you may be better off selling those single inserts :'( and going with the two piece inserts as they are easier to "tweek" ;D
