The older kit (pic #1) is only for 5.0. You can adapt anything with welding cutting etc. But not worth the time. https://www.wildhorses4x4.com/produ...-Bracket-Set-non-AC-only/EXPLORER5ENGINEPARTS
This new unit (pic #2) will work for either 5.0 or 5.8 Explorer front dress. You can also add the A/C bracket if you want to.
https://www.wildhorses4x4.com/product/19201/EXPLORER5ENGINEPARTS
Jim
Perfect, did not know that 2nd bracket existed.
It took a bit to get the older bracket to line up, but once done there have been no issues. I bought an upper idler pulley bracket from a member for the 351W since at that time WH didn't have the 351W bracket.
Can you post a pic of this upper idler pulley bracket? I've got the older WH kit. Probably had it a couple of years now and finally getting around to trying to install on a 351W. A buddy said we could make it work, but I haven't got into the install, only the teardown. Any info would be much appreciated. Thank you.
If you have the "old" version (which we still sell) It won't work with the 351W. Lets exchange it. We can credit you tword the new version that fit both 302 and 351W.
You can always make something work with some welding, grinding etc. Save time swap it out.
Jim
Jim
I just double checked and they're (both the P/S and the A/C brackets) still on the "New Parts" category listings. But they are also literally the last two parts shown!;D
They don't say 351/5.8 in the title, but do mention it in the text.
Thanks again WH! Bracket works like a charm and looks good too!![]()
Sent from my Pixel 3a using Tapatalk
Hey Paul and Jim, sorry but I am slightly confused. I clicked on the two links don't see the the bracket in Chub_Rock posted. I also looked for the bracket in the "New Parts" section. Sorry for the confusion. Thanks guys.
Jason
Thanks Mark.
And I notice that now the #7129 is just three rows down on the New Parts page. So apparently rotating their way through the listings.
Whenever I'm looking for different items along these lines on the website and don't have a specific item description, I just type in "explorer" in the search box and it all comes up on one page: https://www.wildhorses4x4.com/category/s?keyword=explorer
