4xfloored
I am looking for a fuel injected motor , and have found a few some just motor, anothers complete with; serp set up, fuel rails, computer just no harness .... just trying to gauge a value here..
I paid 400 for mine with no intake or accessories. I think $500 is a good deal.4xfloored said:the guy says he'll take $500 for motor, computer A9L,serp acc, but no harness.... sayds it has aprox 78k out of a wrecked mustang gt 92
Awnrie69 said:So, I have a big question.. What are the advantages of going with a 5.0? I found a great deal for one out of a thunderbird.. (400 for the whole car - just wrecked in the front end.. no damage to the engine radiator) I need to know how big of a job it is and all that is involved... I have a worn out 302. Any info you could give would be great because at this point I am almost ready to buy it and figure it out later
Socal Tom said:The 5.0 HO engine was rated at around 200 horsepower net. The roller cam setup gives lots of HP while still being very streetable. A new 75 Bronco engine was rated at about 150 gross HP, which means about 100 net. The later model engines are also much better made. With proper care they can go well past 100K miles. With the older engines 100K meant you were done.
The serpentine setup allows you to run really large alternators without whining and squealing belts. If you go with the EFI, you gain smooth consistent power at all angles and speeds, and no adjustments. The cooling system is also much better designed, so the 5.0s tend to run cool.
Tom
If you switch to EFI then there is a lot of wiring involved, an electric fuel pump needs to be installed, and O2 sensors need to be put in the exhaust. This is all in addition to the engine swap itself. It can be done at the same time though. What year is the T-Bird? If it already has EFI and is in good shape then it may be worth considering. The advantage to the EFI is that you can avoid the stumbling you were having on the trails at SOB last year. Gas Mileage should improve slightly as well. Cost to install varies depending upon what all you decide to purchase. If the car already has EFI (Once we know the year we can tell you what it should have) then the harness can be reworked. Additional cost would be the flywheel balancing (The 5.0 has a different imbalance so that cost would already be there), a fuel pump, and having the O2 sensors installed. There would be some wiring supplies necessary as well. Beyond that most of it will just be figuring out and modifying stuff. Figure on $150 more than it would cost to swap your stuff onto that engine. (This would be going the cheapest route and reusing everything possible plus getting a fuel pump from u-pull-it off a late model F250)Awnrie69 said:is the EFI something i would have to do seperate, what does it do? How much do they run?
Leo73EB said:I have a harness if you're interested. I bought one of Ryan's units, so I don't need the old one anymore.
Not that it matters, but I agree with Broncobowsher's guestimates, save add a hundred to his figures. I've seen these engines go for much more, based on those specs. I have the exact same engine, fwiw. There are "some" mods you'll have to consider before doing this, but I'm sure you already know that if you're interested in going this route.
SaddleUp said:Thread Hijack:
How are things going for you? Been a long time since you've been around here so I wasn't sure if you still had your EB anymore. Will you be making it to SOB 9 this year? My youngest daughter specifically asked since she enjoyed spending time with your little one last year.
Rick Halle (SaddleUp)
