What gears? 351/C4/D20?
rtreads
With 37's what gears do you run??
I am thinking that I will need to go a little lower with the 37's I will be installing. I currently have 4.10's and worn 36" swampers. I will be going to some new 37's. I have a 351 that seams to push the truck along fine now... but I think I am pushing it. I currently get 8/9mpg, but I am not 100% sure that isn't partly due to a carb that isnt correctly adjusted to a mile high. The truck came from kansas.
justinoshea
Gilbert, AZ
I run 4.56s and they are too steep for 37s on the highway. 75mph is 3500 rpm with T/C slip. 4.30 would be ideal for a torquey motor, but I would leave the 4.10s 'cause one ratio is a waste of $1000.
save that $ for an Altas, stak or doubler for trail use.
malcolmzilla
Calgary, AB, Canada
True 35's, 302, C4 and 4.56's rev's a bit high on the highway for my liking... I might go to 37's. Around town its fun. My 302's a dog tho.
Try the 4:10's with the 37's 1st and go from there... How fast do you want to cruise? 55-60 with 4.56's and 37's would be not too bad for rpm's...
33" tire and 4.10 is a great combo. I don't see how 37's could be good on the same ratio?
rtreads
rtreads
Ok so the responces are all over the place... I think I will try it with the 4.10's and go from there. Thought I really want to be able to drive on the highway. I would like to be able to run 70 mph. That would make trips to Moab and Ouray (?) a little better.
What do you think about the MPG? I have heard from some that having sich a tall gear is the cause of my 8-9 MPG?
Thanks again
37" tires and punching a huge hole in the wind, 8-9 sounds about right. Barns are not known for there aerodynamics at highway speeds.
I think you will be disappointed with 4.10 and 37s. I know that 4.10 and 33" was a great overall combo. Friend did the same and went to just 35" and could really tell a difference. When loaded he now sometimes pulls grades in 3rd (NP435) becasue it won't pull it in 4th anymore. And he has some poneys under the hood as well.
rtreads
rtreads
I have 40's and 4.88's. Not really a hiway gear.......more for offroad work.
what do you suggest? 4.56? keep the 4.10??
So yours is too low then? 37" to 40" Is a HUGE difference in rolling distance. much more than worn 36" to new 37".
starkypdx
Secret lab in Oregon
On the 77 I've got an overdrive 4 speed. the 4.10 w/ 33's and works great for around town and on the trails. When I run the 35" boggers it was noticeable difference.
When I calc'd the Brown Hornet with a C4 auto for 37's I figured 4.56's would be a daily driver number w/ 4.88's being more of a weekender with little on highway use.
I can't comment on how the 4.88 gearing is quite yet because THE BROWN HORNET IS DOWN....
bax
Old Member
I have 4.88's with a 37'' tire. great off road and good on the streets going up through the gears. Not an interstate gear. I did have an AOD and it was great with the 4.88's and 37's I have a big motor and lots of low end so going 70 was easy. Now with the c6 a 4.30 would be my gear of choice because of the big motor. if I had less motor a 4.56 would be my gear.
A4x4Junky
South Jersey
I was never able to find a gear I liked for around town / offroad as well as highway without an overdrive of some sort. With a 1:1 top trans gear you will have to sacrifice something.
Anthony
