What Goes Here?
MB Buggy
My first attempt at attaching photos so hopefully it works...
Please see the picture of the cutout on the bottom of the lift gate and the two rectangle holes in the firewall below to the throttle linkage.
Both those spots seem to be missing plates of some kind. Can someone please advise as to what they are?
904Bronco
San Martin, CA
#1 is the hatch anti-rattle, there is a stainless/chrome plate that mounts there with another gizmo that mounts on the tailgate.
#2 early fuse panel mounted to the firewall at that point and engine / front harness plugged into the back of it.
(#2) I attached the only picture I have of my 68, not the best
House
Minutia Militia
Most vendors have most of the parts you need.
Looks like you are missing a few things.
Tailgate:
Anti Theft Post
Backing Plate
Two screws to hold them together
Rubber Post Sleeve
Liftgate:
Anti Theft Post Bezel
Two screws to hold it on
Action
Update
Hey Doug lets see an up dated pic of that 68....I think it looks a we bit different.
Jack
jckkys
The anti rattle picture is out of focus making it hard to what you have and what you don't. It looks like your missing the stainless cover plate and the 2 screws from the bottom. Do you have the post bolted to the tail gate that fits into the recess in the lift gate?
The early wire harnesses passes through the fire with 2 plugs in front and 2 plugs behind the fire wall, where the rectangular holes are. The early fuse box was on the fire wall near there. Your wire harness is, or reproduces the late harness that goes through the fire wall at the far left (driver's side) with a rubber grommet. You can cover them with a piece of sheet metal.
M
MB Buggy
Update: Ordered the post, backing plate and rubber sleeve.
No luck finding the strike plate / bezel / chrome doodad that mounts to the underside on the lift gate and accepts the post. Any assistance on sourcing this is much appreciated.
AZ73
Try Driven 4X4 in Phoenix, They're also a vendor that advertises at the top of the screen.
http://www.drivenautoparts.com/
Also ebay and the used parts section of this forum.
M
MB Buggy
Thanks AZ73. Driven 4X4 knew exactly what I needed and had them in stock...
Now, figuring out how to hold the back plate way up in the tailgate while I screw in the post -- I doubt that is going to be as easy.
ksbronco75
isnt there a access panel on the inside right there to get to the liftgate handle and liftgate rods? could you open that to help with the backing plate?
House
Minutia Militia
The backing plate for the anti theft post goes inside the tailgate.
