I’m considering selling my 1974 LUBR Bronco. I have a lot of paperwork on it from prior owners and what I’ve done, but the basics: power steering, power/disc brakes, air conditioning, 3 speed on the column, and just had a rebuilt 5.0 put in a few months ago. The tub interior has been bedlinered and has an insulated vinyl floor covering on top of that. It has a lift, which I believe is 1.5”-2.5”, but unfortunately that’s the only thing that I know of that I don’t have the paperwork on.
When the new motor was put in, the shop went through the whole thing and fixed any other issues so it runs and drives great now (the shop is probably the best in town for broncos).
Cosmetically it’s in very good shape. The only real rust spot is passenger floorboard, but it’s very firm and I haven’t felt the need to do anything about it. There are a few very minor surface rust areas, but they aren’t major and in my opinion don’t look bad at all (can hardly notice them from 10-15 feet away).
The only issues I know of are:
• I’ve never used the aux gas tank, would need to be cleaned before using (and I can’t say for sure that nothing else is wrong with it, but prior owner told me it was okay)
• speedometer on the gauge cluster works, most other things on the cluster don’t. There is an aftermarket temp gauge on the column that works fine.
• The dash cosmetically is bad. The paint isn’t great and there is a hole for the radio but the radio is in the console.
• Small dent in the hood – it’s not all that noticeable but it’s there. I would suspect a body shop could fix it relatively easily, I just haven’t had time to take it yet.
Overall it’s a great bronco that needs nothing as is and could easily be a daily driver, but I think a new dash, fixing the gas tank, and a paint job would go a really long way.
So, my question is: what do you think this is worth?
Hopefully this link works to see photos, will try to correct if not
http://s958.photobucket.com/user/txhorns_2009/library/1974 Bronco
