Idealy you would use an exhaust gas analizer. Check you CO levels and adjust from there.
If you have a spare O2 sensor, put that in the exhaust, set up your volt meter and dial in around .4V
I don't understand the reasoning behind it, but the instructions on my Holley 4160 600cfm says to hook up vacuum gauge to manifold vac and adjust the idle mix screws for max vac. reading. I'm not saying it works, but my plugs are just the right color. Could be just dumb luck.
go find a nice long stretch of road with no traffic. put it in gear, and romp on it! pretend gas is 99 cents a gallon, and get it goin as fast as you can.
once you're goin as fast as you wanna go, turn the key off and bring yourself to a stop. pop the hood, pull a couple plugs and see what they look like. Instead of pulling all the plugs, I like to pull one from each corner of the engine. if the plugs are white, it's too lean. if they're black or real dark brown, it's too rich. you're goal is a light tan.
or if you're really lazy, just look at your tailpipe. it should be just a bit sooty
X2 on that. It's called "reading the plugs". Do a websearch and you'll find more about it. I'll add the disclaimer to keep ugly74 from getting sued: Don't do this if you have a locking steering wheel or other loss of control issues associated with turning off the engine while driving
I killed the ignition to load up the engine with fuel...so that once I gave it spark again, it would go BOOM!
