...Plus most people say not to use a drop trac bar bracket with a TRO. Do the F150 knuckles have the same clearance problems?
I think what you mean is that most say not to use a dropped pitman arm with a TRO. Or maybe to use a riser instead of a drop bracket.
You may still very well have to use a drop or riser bracket for the track bar.
Or not...
You can take most stuff as gospel with EB's. Gospel in a general theory sort of way that is. ;D
In other words, no matter how many people have done exactly what you want, you still might have to put all the answers together, read between the lines and still make up your own results. All because EBiDaYRMV (Every Bronco is Different and Your Results May Vary).
So while you might get extremely close (which is often good enough too) by using someone else's results that did the same thing you want, little things like: Who's pitman arm did they use? Who's drop bracket did they use? Who's tie-rod and draglink did they use? And just how long is their draglink anyway.
Oh, and that doesn't include what steering box did they convert to, if different from stock. And where on the frame is it mounted.
When you start narrowing it down to one or two examples then, you might want to get those little details added to the info so you know for sure where they were coming from. And if it would apply to your rig.
So while you can take everything under advisement, the ultimate results may just have to start with you experimenting and not welding anything on permanently, or reverse-tapering any holes, until you try it on for size. So to speak.
That's kind of what I did. Before I had any examples to shoot for.
When I did my 3.5" lift with F150 knuckles, I realized right away that the initial testing showed things weren't going to line up like I wanted. I ended up buying 3 different brand pitman arms, 3 different brand drop brackets (before risers), and shortened an F150 steering link setup to make it all work together in a TRU arrangement.
Took back everything I didn't use and have never looked back. Mine was working fantastically (when I was driving it that is) and driving super steady down the highway at any speed I cared to take it to. No appreciable bumpsteer or other foibles.
That's likely all going to change shortly when I put in my 4x4x2 box.
Sorry to be such a long-winded nervous nelly, but when it comes to absolutes and EB's, they're often mutually exclusive and you sometimes just have to punt.
As said before... "Your results may vary."
