When looking a little deeper at what it is that's unique about the Truck Avenger I only know of a check valve in the metering block that controls fuel that would otherwise splash out of the booster venturi. The looped vent tube,spring loaded needle & seat.and annular discharge booster veturis are common features of many 4150,4160,and 4180s. The odd CFM ratings don't mean different venturi or throttle bore diameter. The best I can tell a 470 is a 450 size,the 670 is a 600, etc. So if you have a well tuned list 4548, a 450 CFM Ford carb. Is it worth $400 and the time to dial in a 470TA to have a check valve in the metering blocks?
