You're right on that oil change thing. My wife's new minivan only requires an oil change every 7500 miles per manufacturer's recommendation. Given the choice I'll take the advise of General Motors before Jiffy Lube. By the way, I also run 87 octane in my '72 with no problems. Like was said before, all the independent studies have shown that higher octane gas doesn't improve performance or milage. If you run a high compression engine you may need it, but otherwise run the lowest grade you can without pinging. Save your $$ for bronco upgrades!
