Conventional: Castrol or Valvoline changed every 3,000 miles.
Synthetic: Mobil-1 changed every 4,000 miles.
I have rebuilt enough engines to know that Pennsylvania based oils (parrifin based) are sludge and varnish generators that cause significant wear over Castrol and Valvoline. I would not even use these products in my $100 lawn mower.
I would use Castrol Syntec, but it is not a true synthetic ... it is a "modified" conventional oil. Mobil sued for misrepresentation, but lost due to semantics over the meaning of "synthetic".
Don't believe the extreme synthetic claims of extended oil change intervals (5,000+++ miles).
For every 100 gallons of gasoline burned, the following is produced during the combustion process …
• 90-100 Gallons of Water
• 3-10 Gallons of Unburned Fuel
• 0.5 to 2.0 pounds of Sludge
• 0.25 to 1.0 pounds of Resin and Varnishes
• 1.0 to 5.0 pounds of Nitric and Sulfuric Acids
• 6.0 to 10 ounces of Insoluble Lead Salts
• 1.0 to 2.0 ounces of Hydrochloric and Hydrobromic Acids
While most of these agents escape in the exhaust and some vaporize when subjected to extended oil operating temperatures, a percentage does accumulate … and continues to accumulate in the oil until it is drained with the next oil change. While synthetics are superior in dealing with these byproducts, they do not not eliminate the need for reasonable oil change intervals.
