What Seats Fit in a Bronco?
Dawg_enD
Mustangs are made to fold forward, since it's a coupe. I'll post a picture tonight or tomorrow of them leaned forward.
Thanks! I'm a little worried about the seat hitting the windshield, or just not having enough room in general. Pics make it all easy!
Thanks again,
-Mike
Spartan76
I just put Pro Car Elites in mine with the WH brackets. Super easy install. I put them in on the highest setting, height is okay with visibility. I'm 5' 10". Only adjustment I plan to make is put the rear of the seats on the middle setting, lowering just the back a bit. Level they almost feel high in the back, probably because the way the original seats were positioned. Very happy so far.
lonesouth
ford ranger bench up front, 2x expedition middle row middle seat(1 from two vehicles) in the rear. The expo seats fold flat and have an integrated shoulder belt.
check build thread in signature
sprdv1
REBEL
Get ya good good off road seats if you'll be wheeling much..
Corbeau, PRP, etc...
B59
Does anybody else have cat problems, jacking up your seats, like clawing and peeing on your seats? I feel like I want to wrap them in foil and hook a battery lead to them and a ground on the floor!
Slednut10
Guru? That's funny!
X3 on the Probe seats. Matter of fact, I think I stole the idea from Rev ^^^^;D
bronkenn
Bronco Guy
Southeast Ohio
.22 shorts solve a lot of cat problems.
1strodeo
Squirrel Watcher
Wisconsin
Only if i leave the door open...but I'm fortunate enuff to keep mine in the garage. I always keep something not quite finished - window missing, broken or won't roll up, missing/leaking weatherstrip etc. to convince the wife the Bronco needs to be in the garage ;)
lonesouth
That's a problem I wouldn't have for long.
sk1nw4lk3r
Thanks again,
-Mike
Seat can be closer/further from windshield when folded forward based on where you weld the bracket to the seat. I am 6'4, wanted my seats as far back as physically possible when slid all the way rearward.
ObscureMachine
Seatbelt Orifice Officer
World Headquarters
I've got seats from a 2014 Mustang GT Premium in mine. Welded them to Corbeau Bronco seat Brackets.
Had the rest bench custom upholstered to match. Get's lots of compliments, and the seats are made to lean forward aggressively for access to the rear seat.
How did you mount these? Did you use a bracket or did you fab something up?
76YETI
KC METRO
Corbeau XRS seats, A vendor (CCOR) on here ships them for free but they are pricey! I sat in a pair of the TMI seats at LMC Truck, wish I would have before I orderd the Corbeau as I liked the stock looking seats made by TMI better.
76YETI
KC METRO
I'm hoping these will work but I don't have the mounting brackets how-to figured out quite yet.
Hi
New to the group, and saw your reply in post about seat swaps....
Did they work out? I like the look of front with center console and rears look good to. If they worked out was view good through windshield? What did they come out of?
Thanks Eddy
Howard2x4x4
Hi
Thanks Eddy
Q. Did they work out? A. I think so, pretty sure.... 20240229_175620.jpg " like the look of front with center console" 20240113_135400.jpg Thank you. Seems I have about 37 1/2 balls in the air right now, and seats and console are both in that number.
Q. "If they worked out was view good through windshield?" A. At this point, the view through the windshield is of the desk at the front of my barn. It would be better if I would straighten up the desk some.
Q. "What did they come out of?" A. Ford Freestyle.
Scoop
Have Bronco, Will Travel
Cuchara, CO
Q. Did they work out? A. I think so, pretty sure.... View attachment 927118 " like the look of front with center console" View attachment 927119 Thank you. Seems I have about 37 1/2 balls in the air right now, and seats and console are both in that number.
They look great but I think they'll be too high unless you're height challenged. The console looks awesome!
Howard2x4x4
"They look great..." Thanks Scoop. I think they'll be too high unless you're height challenged. You may well be correct, Scoop. As I recall, I couldn't go lower due the power seat motors. Maybe I'll have to get my butt checks sectioned. Or go topless all the time. The console looks awesome! Thank you Scoop!
