What throttle cable bracket for Fitech
377
The Bluegrass State
I just installed a Fitech TB on my rig and I am really happy with how it turned out. I have run into a slight problem with my Lokar throttle/kick down cable bracket. When a depress my gas pedal the bracket moves toward the front of my engine. It seems like the set screw Lokar put on the bracket to keep it from rotating doesn't really work with the Fitech base because there is no where for the set screw to rest and keep the bracket from rotating. I am hoping somebody smarter than me ran into this problem and figured out a good fix. I am also using Fitech's return springs/bracket on the front of the TB. Thank you in advance for any help.
c0astie31
I am using bcbronco combo throttle/lockdown bracket
Mounts on carb stud, all tight it don't move at all
Ink1967
I used the stock throttle linkage with minor ajustments to the rod works nice and smooth. For the kickdown cable I used a small plate which is mounted to the manifold, drilled a hole in the plate for a Heim joint (allows for changing the angle of the wire slightly) and passed a lokar kick down through that. This keeps the kickdown steady and does not rotate or move like the corner carb style mounts. Not sure why Fitech could not just mimick the flat spot on the corner of their throttle bodies so it would accept stock and after market cable brackets.
Hazegray
I have the Lokar AOD/Throttle setup on mine and had lots of movement at first. I then made a plate that bolted down to my intake and did a 'lil welding to connect to the Lokar bracket...very solid now.
