Wheel back spacing/offset for superduty axles
meanjean73
Oregon
In the process of adding 2004 superduty axles on my 73 Bronco build. Curious to know what others with this setup are using for wheels?
I ordered some beadlocks 17x9. 4.5” backspacing with -12 offset. OEM wheels for a superduty are close to 0 offset.
With the axles wider than stock I wasn’t sure if I should get a wheel with 5 inches or more of BS to prevent the axles from being even wider.
Yeller
Rogers County Oklahoma
I would do more, like 5 or 5.5”. I see your in Oregon, that 1 or 2” is going to be important. I always try to keep overall width down to 81” so it fits easy on a trailer. Most car haulers are 82-83” between the fenders.
meanjean73
meanjean73
Oregon
Thanks for the reply. I narrowed the axles down to 66” but if 5” BS would help ensure fit on the trailer l should see if i can change my order.
rocknhorse76
Bronco owner since 1993 💪🏻
Central WA
You should be ok with what you have if you narrowed to 66”. My axles are 65” and I’m right at about 81-82” overall.
