I made a couple modifications to the sticker as UNC mentioned. Below is a scan comparing them. I'll refer to the original sticker on the truck as the original, and the sticker UNCbronco made as the repro.
Top one is the new one, bottom is the repro. Changes listed below:
- Made background color slightly darker to match my OG (which might just be darkened with age but oh well
- Changed fonts and font sizes throughout to better match OG to my eye
- Corrected mixed O's and 0's
- Added missing "DWELL" word
- Removed line between choke setting lines
- Changed choke setting from 3 Rich to 2 Rich
- Changed timing setting from 12* to 6*
- Changed manual idle RPM from 800 to 900
- Changed number at bottom from 734 to 737
- Changed part number to D4TE-9C485-CC
- Increased size
Below are pictures comparing the new and OG stickers, as well as the new and repro stickers. The lighting is a little off and I had my prototype sticker made in a glossy finish, so the new sticker appears lighter than either of the others. To the eye, it's darker than the repro and slightly lighter than the original.
There's a few additional changes I'd like to make, listed below:
- Move "0.5% CO MAX" for manual transmission left to better match original
- Move RPM values slightly left to better match original
If you don't feel like waiting however long it'll take me to make those changes, then below is a hi-res copy of the new sticker.
Go to whichever custom sticker place you like (I used
carstickers.com) and upload that image. Use a matte finish, permanent adhesive, and set the size to 4" x 2.875". I won't be ordering a large batch of stickers and reselling them, but if someone else would like to then go ahead!
If someone has any other changes/comments please post them!
