Where can I get this spring? (clutch linkage)
Nothing Special
Nothing Special
.... The balance of the linkage must be holding it there because there isn't anything else that could....
Having said that why would you think I didn't know that it was gravity acting on the weight of the parts that was giving the balance?
My point was that you had seemed to think a return spring was needed, or at least that without one only the pressure plate springs would be lifting the pedal. But after I said that you come back seeming to say that it's obvious that a return spring isn't needed.
thegreatjustino
Red Head Grease Monkey
Stockton, CA
You seem very confused. I've given my input. If you'd like to continue scratching your head over the situation, I have nothing further to ad.
Nothing Special
Nothing Special
I guess things aren't always as they seem. I'm not at all confused. My only confusion was about where the spring went. That was cleared up by post #8. After that I've simply been saying what I had, in response to your questions and statements.
