Yes there is a lot of varitions of the 2100 the smallest was like .98 to as large as a 1.30 if I remember right. The stock bronco came with 1.08, which if you were going to stay 100% stock would probley be best.
If the carb you have is a stock mustang and it is a 1.12 it probley will work very well if you are runing headers and open air cleaner, but it might work very well in a stock applacation also, so in the end it sometimes its a roll of the dice. So I guest what you want is between 1.08-1.12.
What ever carb you get in this size range take the numbers stamped on the front mounting tab were it bolts down and used the specs for that carb if you rebuild it, if it a mustang use mustang specs during the rebuild not bronco specs.
A couple last things if the carb you looking at, looks like its been threw a mass rebuilder (exchange at a auto parts store) I would pass,because you don't know what you have inside. Finding the OEM manual choke parts is a good way to go, it solves a lot of problems if the carb is trying to be used with headers. Alot of pick-ups used them and all 2100's are the same.
