...(Total Hijack sorry OP), I am running the explorer serp but I have already switched to the 2/0 charge cables from JBG and have 175Amp mega fuse attached. I have RJM's alt connect but what do I hook that to? Is that to trigger the gage?
Hey Steve.
Do you have the RJM 3G or 4G adapter harness as well? Oops, you said you did I think.
If so, the basic way (ignoring the dash light for the moment) is as follows:
1. Run the 2/0 wire straight to the battery (or starter relay) as it sounds like you've done.
2. The small Yellow wire from the RJM connector to the output stud of the alternator (along with the main 2/0 charge wire). This is the sensing wire.
3. The Green w/red wire needs a 12v switched source. Your RJM's main engine harness should have a plug ready made for this, and gets it's power (along with the ECU I think) from the firewall connector on a stock harness, but from the passenger side trunk on the Centech. He sells an adapter/extension harness for aftermarket harnesses like the Centech, because his standard plug is right there behind the engine. But there should be a plug right there by the number one injector plug that attaches to the alternator harness.
For the Centech, that should be the Green wire marked "REG" there along the passenger fender. With the Centech though, there are at least 2, if not 3, wires right there with 12 volts on-with-the-key. You can use any of them.
4. Depending on which alternator adapter harness you have, there may be a White w/black pigtail with connector already on it. That's your Stator wire and is usually not used on an EB.
The proper way of completing the alternator circuit would be to add the dash indicator light into that circuit that turns the alternator on. There are diagrams showing how to do it here and in the shop manuals with diagrams of vehicles with a light instead of an ammeter.
The system will work without a light, but it's been argued that it's better for the alternator if that little extra resistance from the light bulb is in the circuit.
I don't know how that works, but it's just good practice to have a light anyway. Even if you have a volt gauge in addition to it.
You said on the Centch that the yellow alt wire and red bat + ar ethe same wire on different ends correct?
Correct. And you've just made the Yellow half unnecessary with your 2/0 charging cable. So you have options.
1. You can leave the Yellow wire attached to the alternator, even though it's not really doing anything.
2. You can cut it off and safely cover it so it never gets touched by anything (since it has constant battery voltage.
3. You can re-route it now, to power a large distribution terminal/stud for an easy place to hook up additional accessories later.
Up to you.
