which lift kit, progressive coils?
wesleydax
well ive been looking at replacing the rear springs. but now im thinking about replacing the entire lift with a new one. My reasoning is that the rear is mushy, and sways a bit. it looks like the rear is saging just a little with the top on. The lift thats on it is a 3.5 super lift that i put on in the late 80s. It has a 1" body lift as well. Would a new lift help handling, not that they handle great to start with, are the new progressive coils any good?
Broncoaddict
I think a upgrade on some new coil springs and leafs would give you a smoother ride. I've used a couple vendor suspensions in different broncos, currently running wildhorses 3.5 and love the ride. New bushings and springs would prob change your ride quality greatly. I see your in Cleveland, I'm in ooltewah, I have some 3.5 wildhorses coil springs if you decide to go with some.
Apogee
Tangent, OR
Newer springs and shocks should definitely improve your ride quality, however sway bars will do the most to resist body roll. You know what they say about the right tool for the job. As for your lift levels, your rig looks pretty close to level as it is, so if/when you start swapping springs, you're going to be in the same boat trying to get the exact stance you want...level, forward rearward raked. Some vendors offer free exchange programs on springs, although without breaking them in, I've never quite understood how that really works.
wesleydax
wesleydax
Broncoaddict. are your springs the progressive ones? I hate to buy a complete kit cause i just replaced c bushings, shocks, and leaf bushings.
bknbronco
North Metro, MN
if your rear is mushy id keep it! If you want a soft front spring then you dont want the progressive. I have JBG 5.5" rear springs and there front dever coils. Front is fine even with dual shocks, rear is stiffer than id like and thats with one soft shock.
Progressive springs get stiffer as you compress the spring. For a tar baby they might be fine.
01Dudley
Knoxville
Duff coils are progressive and yes as they compress they do get stiffer just like any other progressive coil. That is what gives it a nice ride. You don't want them stiff it feels very solid and too soft will make it feel mushy and bouncy. Progressive w/our 70/30 shock makes for a great street riding Bronco. It would also improve the ride by going to dual shocks on all 4 corners.
