I have seen the caps but not on the broncos diffs. I find them on the d-20, What ever, I may have just missed them but the idea is when you drive thru water the air cools causing a vacuum that sucks water into the diff. The hose goes into the frame front and rear and I guess that works unless you drive through deep water. The caps have a disc to keep water from getting in but seems to only work when new. You should always check the fluids for water after wheeling in water.
