Who has replaced body mounts? Need help
anziosaint
I recently got my bronco design fiberglass tub and need new body mounts. I have been told that the mounts from jeffs are super stiff and really meant for the steel tub so essentially i'me asking..... Who makes the softest body mounts? The softer the better for my glass tub. Within reason obviously. If anyone knows, pass it on. Especially you guys who have glass tubs. I really want plush!
mp
Austin, TX
you probably have urethane, which will last forever. Solunds like you want/need rubber, which will pack out/squash over time. Most of the Bronco houses sell the rubber body mounts.
Revelation
With the steel frame work in the Bronco Design tub stiffness of the body mounts should not be an issue. But if you want soft I believe the rubber ones are softer than the poly. should be the same from all vendors.
A
anziosaint
I didn't realize the venders were still selling rubber. I have just noticed all the hype about poly and how it is superior to the factory rubber ones. I believe that to be true but I really think soft rubber will be better for my application
NYLES
been running poly on my kentrol 4 years, aint gonna hurt it.
