Who has the Wild Horses 1.5 inch lift kit?
nickeboy
Who has the Wild Horses 1.5 inch lift kit? I've searched here for one and haven't seen anything. I am building a 71 lubr and want it to be close to stock. Did you need to do a new trac bar or will the stock one work well? Also, what size tire and wheel combo did you go with?
Yeller
Rogers County Oklahoma
you will not need to change track bar, pitman arm, ect. it will be all good. The 1-1/2" springs with stock replacement springs will net a nearly level stance when complete.
nickeboy
nickeboy
Thank You
bmbm
I get confused easy so is this using stock coils front and 1.5" leafs back?
Yeller
Thank You
My apologies, I was not 100% clear. 1-1/2” coils in the front and replacement stock height leaf springs in the rear. I can confirm if they are sourced from Wild Horses barring any crazy heavy bumpers or other weird items the bronco will sit level. I cannot speak for the other manufacturers/suppliers but would assume the same results.
