Did you know that Wild Horses 4x4 has used parts too?
Alpacket
In case you were unaware Jim Creel started Wild Horses 4x4 almost 25 years ago by parting out Broncos.
Over the years Wild Horses 4x4 has moved away from selling used parts and that left us with a good amount of inventory around.
Next time, if you are needing a factory used part, feel free to call or E-mail us and we can dig around and see what we have.
I think I see what I need in the pictures. The snorkel for a 302 air cleaner? I just need the snorkel.
MarkH@Wildhorse
MarkH@Wildhorse
Stockton, CA
How about 3.89/3.92 gear set??? would a 3.89/3.73 be compatible?
3.92 gears are kinda an oddball, we don't even see many of those new.
a 3.89 and 3.73 are too far apart to run.
What year are you looking at?
We have some loose snorkles but over the years they changed.
Moon's74
Henderson, NV
D44 gears
Looking for a set of 4.10/4.11/4.09 ring and pinion for a 74' D44 limited slip, or possibly the factory limited slip carrier with the gears. Either way I'm looking to upgrade my factory limited slip 3.54's to 4.11/4.10/4.09's. Thanks.
MarkH@Wildhorse
MarkH@Wildhorse
Stockton, CA
Got a good set of chrome Bumperettes for a front bumper?
We do have some, but "good" is hard to say, if I wanted some, I'd just get them new with pretty chrome.
We do have used gears, but we don't have the other Power Lok that you'd need for 4:11's
What I'd do is use that same power lok, maybe add a rebuild kit for it, then just run the thick 4:11's gears on it. You can give us a call for a quote on all that.
Do you have any Radius Arm C Caps.
They all just left to someone else, I'm sorry.
what about Dana 20 t-shift gears?
Loads of gears, what gear did you need?
Lower driver side radius arm shock bracket
I am in need of a shock bracket that mounts to the radius arm front side. I think it is original.
El Kabong
Driving stuff Henry built
I stopped in the other day & you guys had the "experienced" chrome headlight rings that my Bronco wanted. Thanks!
BluebroncoNC
Asheville, NC
Mmm, not original, but it is the "old school" method of putting duel shocks on the front. Some prefer the two back method now with a hoop mainly because it is easier to do a tie rod over the knuckle steering system. Having said that, give Wildhorses a call, if they don't have them, I bet they can steer in you in the proper direction.
