dougefresh47
- May 24, 2010
- 9
Okay Im doing a complete frame off on a 69 EB and I have a question?
It seems with the wheels tires mounted to the frame (no body on, just motor) the Front axle looks to be approx. 2-3 inches wider than the rear...is this common or did I get a wrong size axle?
I swapped the original Dana 30 in the front to a dana 44 and added discs all the way around...Tires are 35s and I haven't connected the drag link or tie rod between the wheels yet.
Any recommendation on adding rear wheel spacers or should I just leave it?
Any help would be much appreciated....
Doug
Doug
