- Sep 27, 2007
- 2
66-77 early bronco. I have a project that I started 5 years ago and then I got married and had kids. This is a great start for someone. It is a frame up project, what I have together at this point is the front and rear axles with new bearings and new warn lock outs up front, brand new brake line kit, new drums all the way around and kits inside (needs new cables inside the drums),a 351W with 4 bolt mains that was bored 060 over and hot tanked, new engine kit, edelbrok intake to match the cam, this is bolted to a one piece bell housing c6 (hard to find) with a new b@m torque converter inside. I have the original transfer case and another new process that came out of a later Bronco, I have a brand new B@M shifer, steering column, worm gear and all the other steering components (these are not new). I have the original front and rear drive shafts, a 79 front end with disc brakes another 9 inch ford rear end, a 4 point roll bar, pedals and brackets, new urethane bushings, new radius arm insersts, wildhorse drop brackets for the lift, new body bushings, door window mechanisms, a 289 block that I dont know anything about, the original transmission, the old front springs, a hard top that is in rough shape. There are many more little odd ball things that I can not remember. Well, I hope that this interests one of you. I really do not want to part out what I have already put together, somethings I would but I would rather sell it whole. Dont be afraid to ask questions and put in what ever offer you have in mind. I will get some pictures together and post them when I have more time. Thanks for taking the time to read this.
