    Discuss it more here:
  • The Classifieds forum is a place to buy and sell, not an open forum for people to give their opinions on Bronco values. Unless the seller specifically asks for help on pricing, please don't critique quality or asking price. If you're not interested then move on.
    Thanks!
CA Wild horses Delphi power steering box
Status
Not open for further replies.
350hertz
This is Wild horses style 4 bolt box has correct sector shaft to use your stock pitman arm and much stronger great set up for the budget build
ryes
Are there any better boxes with 4 bolt mounting?
Not sure on your question but just as a heads up, only the two bottom bolts line up on the box being sold on this ad. You will still need to drill for the 3rd hole (unlike the Delphi box from wildhorses which has been modified).
BroncoMZ
My frame has 4 mounting holes. Each hole has a sleeve welded within the frame making it a pain to move the holes. The 4 bolt pattern on my frame is for a PSC box which Is no longer sold by PSC.
On the Boregson/Delphi box, the two back holes are slotted...I don’t like the bottom slot as there is very little material remaining to the edge.
I’ll check with WH on the dimensions of their box with the 4 bolt pattern.
Status
