Wild Horses Shorties
smerrill
Has anyone installed any of the shorty headers from Wild Horses. If so, are there any clearance issues with clutch linkage? Pics?
I also have the 3 air injector ports on my heads which will require some modification of the header flange so I want to be sure of other fitment problems before I order them and damn sure before I start grinding on them.
SM
cgbexec
Naples, FL
I have them on my 1976. My body is off but the engine and trans are installed in the frame. The linkage is hooked up with the exception of the pedal rod and that is above the header. The clearance is great. You can also get the starter in and out easily with the header in place.
scotts77
Marietta, GA
I have them. Absolutely no issues at all. Top shelf product.
Here's a couple of pics for ya'. Yep JBA . Also, I had to order 45* angle plug boots to clear the headers. Straight boot will not work.
DonsBolt
Chestnut Hill, Mass
Your signature tag says you have JBA shorties....so are you saying JBA makes the shorties for Wild Horses?
SM
Yes the Wild Horses headers are JBA, but from what I have heard they are different from there other headers. They are modified to fit the bronco, and WH has a exclusive on them.
I also have the WH headers, no pboblem clearing the clutch eaqualizer bracket, or any frame issues.
I can't help with plugging up any injector ports
S
smerrill
Hey I really appreciate the pics and info. I guess Wild Horses it is then. I bit pricey IMHO but ya get what ya pay for.
SM
ransil
I pretty sure my Bronco was used for the prototypes, I had JBA make me a set of headers in 1992 or 1993. Mine was a 3 speed at the time.
904Bronco
San Martin, CA
There are clearance issues if you have an AOD, on the passenger bellhousing side. The flange rests on the bellhousing and you need to do some triming... Mark at WH is aware of this... Great product, good quality from JBA and WH
77broncoguy
Grand Rapids, MI
I've got an auto, so no help there, but I'm really happy with them. I've had to remove my starter a couple of times, and it goes in and out no problem. I did have to modify my dipstick tube a little (tubing bender), but no biggie. I love them, I'd buy them again and again.
theshadow
i used BBK mustang shorties, much cheaper and good product, but I had to pay the price when they ran into the clutch linkage:p now i use a hydraulic clutch
S
smerrill
If you have doubts call them and ask.
yup that's good advice %) ...... and I did, they arent going to tell me WHY their's are so much more expensive or who makes them. By asking here, I not only found out who makes them but practical hands on installation experience.
br0nc0xrapt0r
Loves pickles
hey thats great why don't you buy them some where else then if you think they cost too much?
S
smerrill
Any place else you can recommend to buy them? You've shared so much wisdom in your other two posts here, I hate to bother you for anything more.
SM
br0nc0xrapt0r
Loves pickles
your a smooth talker don't ever change, the first post was because you never said anything about talking to wild horses which the best way to get product info is to talk to the dealer which you did but made no mention of, the second post was sarcasm Donsbolt already stated that wild horses is probably the only place to get these "jba" headers. Don't worry I won't try to help you again since you are so unreceptive.
S
smerrill
My comment to Donsbolt was not intended to be sarcastic. It was only after he amended his post adding pics did he acknowledge the JBA info. Your post assumed I did no homework so you offered your only bit of advice to "call em". I am sorry if my sarcasm to your advice hurt your feelings.
Thanks again DONSBOLT for your help!
