wild ride to work today
wades76
Monroe, GA
I'm driving my bronco to work this morning cruising along the interstate about 60. when the rmp's drop to 0 on the tach but the engine is still running I put the clutch in and the rpms come back up I get on the gas again and bam the biggest explosion I've ever heard from a vehicle sounded like a shotgun went off in the truck followed by a bunch of little blasts. so I get off the interstate and look under the truck and my mufflers had spilt wide open. So I limp along the rest of the way to work with this miss firing going on. I do some checking an find that my coil had gotten loose and it was jumping fire to the water outlet on the intake. just a word to the wise make sure your coil is well mounted. It scared the shit out of me. So I guess I'm off to get new mufflers tomorrow. Is there anything else that could of been damaged by this that I should check before driving it again?<br><br>thanks,<br><br>Wade
SteveL
Huge chevy guy
Hawthorne ca
I would listen for any strange knocks incase any of the internals got bent when misfiring. That would lead to a bigger more costly boom....boom...ka boomboomboom.
Trigger
It gets your mojo going doesn't it. I had a 68 Camaro in high school, I was getting on it pretty hard and heard a big bang and clatter and it died, walked home and got my dad, he took a look laughed and found that the temp sending unit with the metal coil around it went across the distributor leads and shorted it out. I was so happy, thought I blew it up.
Trigger
I used to do that trick back in high school. Get cruising down the road, turn off the ignition, pump the gas a couple of times, then turn the key back on.
I was lucky, I never blew up the muffler, but I got nice fireballs out the exhaust that exited out the side under the passenger seat.
I liked doing it on an unlit road on a moonless night with a passenger who I never did it to before ;D ;D
sicaz66
san diego
we used to drive by my high school back in the day.never saw so many people hit the floor so fast in my life. ;D ;D ;D
El Jefe
Did your coil just work its way loose? or wasn't it tightened down before?
W
wades76
Monroe, GA
[quote author=BroncoEd link=board=5;threadid=14441;start=0#109198 date=1045844780]
[/quote]
I don't think I had the mounting bracket tight enough around the coil and it slid forward pusing the coil wire boot off of the top of the coil and it was too close to the water outlet on the manifold. I tightend it up and moved it. its running fine now
