Will Bronco Oil Pan work with Liberator Dart 363 Block?
betzgb
Does anyone have a recommendation on oil pans for a 363 block from Dart? I would like to use the Bronco stock pan if I can but unsure if modifications will be required. Send photos if you have this setup and you had to make modifications. Thanks!
bax
Old Member
No. The one piece rear main seal makes it different on the rear seal of the pan.
I'm going to say it should work. I know of late model 5.0 engines with early pans in mustangs and Broncos all the time. The only engines that typically have issues when converting to 1-piece rear mains are chevys.
Being an 8.2 deck, and what I find it states that stock accessories fit, I'm going to say it will work. The only thing that has really changed is the dipstick location moved to the block. Might have an extra hole to plug.
But your best answer, follow this link and ask directly https://dartheads.com/contact-dart/
