Jeepincj7 said:
Not with that Bolt pattern. IIRC, all the waggies had 6x5.5" bolt patterns. The J10 may be an exception, but if they are on a D44 front in one of those rigs, and have a 5x5.5 pattern, then they will fit.
OK, I think we need a little clarification here.........the question asked whether flat top Jeep D44 knuckles would fit on the EB D44? And, assuming we're referring to ones from a Wagoneer or J-10, the answer is still
yes, they will bolt right up. You then bolt on the proper year spindles and use the 5x5.5 Ford hub/rotor combo and you're good to go.
However, the second part of the original question is a little confusing. It seems like you're referring to the bolt pattern of the hub. The flat top knuckles you're referring to should have a six stud pattern.
Todd Z.
