Will this Autolite 2100 work with a '70 stock 302?
hollowch
Midland, TX
Had to replace my Autolite because of corrosion, so I ended up buying this one for pretty cheap. I guess I should have asked you guys this before, but will this one work on my '70 302?
Reason I'm asking is because I notice a difference in this one and mine.. This one has a 90 degree fitting coming out of the top cover where the float resides and my current one does not. What is that fitting for?
http://www.ebay.com/itm/32088433316...X:IT&_trksid=p3984.m1497.l2649#ht_2107wt_1180
Monster Mike
It will run but it may have to be tweaked. The venturis on a 1.21 are bigger & I believe the jets are to. Theres a good chance that carb came off a 400.
I put that on my stock 302 in my 76 & no matter how much I played with it I could never get it to run like the stock 1.08
My 1.21 didn't come with that angled tubing off the hat above the fuel bowl so I don't want to guess what it does w/o better pics. Someone else will know.
hollowch
hollowch
Midland, TX
crap.... well, I guess I could always just clean it and flip it for the price I got it at... shucks
Monster Mike
Thats just my experience, some may have had better luck. Its not difficult to try it & feet to dial it in. hell you might have a better luck than me.
turbotim2
____________
The carb in that ebay ad is a Motorcraft 2150, not an Autolite 2100. Just to clarify...
hollowch
hollowch
Midland, TX
Yes, don't get me wrong, the two are similar and may share some parts but that is a 2150.
I wonder if I could just swap my 2100's venturis and jets into it?? All I really need is the main body assembly because my old one is corroded.
turbotim2
____________
I can't answer that but maybe someone on here can. There are often stock carbs in the classified section on here for cheap. I picked one up for $20 recently.
bmc69
The 2150 uses a different power-metering design...The boost venturi assy is different than the 2100.
I would simply bolt it on and try it.
Monster Mike
That 2150 is most likely a larger cfm than your stock 2100. Just swapping guts most likely won't help infact for me it just caused more problems. the venturi bore on the 2150 should have a larger diameter than your stock 2100
1970mule
I got one if you want $40, i had it on my 1970 302 worked well, it was last on maybe 4 years ago. just pm me if you are intrested
