Winch rebuild
knack
Pulled my Warn X8000i apart today. Ignoring the old "if it aint broke, don't fix it" theory.
I bought it new back in about 1996. I'm sure it's been used less than 50 times since then. Other than not free-wheeling as easy as I remember, it had been working OK.
Boy, am I ever glad I looked inside this thing. Yuck. Hardly any grease left in it anywhere that hadn't turned solid. Lots of rusty crud to clean up. Assuming a good soaking in penetrating oil will loosen up a stuck hex shaft, it looks like I'll get by with replacing only some brushes in the motor (one was stuck in place,) some gaskets and maybe a ball bearing.
broncoman1972 did a nice job describing how to do this rebuild in a post back on 4/13. X8000i seems pretty similar to what he was working with.
http://classicbroncos.com/forums/showthread.php?t=223625&highlight=warn+winch+rebuild
I'd highly recommend some preventative maintenance if you've got one of these units with a few years on it. Good January project for those of us who are hunkered down by the wood stove instead of cruising a beach somewhere.
Wyldebill
Berthoud, Colorado
I would check with Warn about the grease thing. Every winch I have taken apart had the same look. Superwinch told me that it is normal for the type of grease used in the gear case of their winches. The solid look I mean, not the lack of it.
K
knack
The grease looks to have a lot of molybdenum in it. There's not a lot of galling or other damage even though it's mostly dried up. Did its job.
