Wind Noise...make it stop
Tasty Geezer
Has anyone been able to completely elliminate wind noise while driving? I have all new rubber on windshield and around doors. At around 30+mph the whistling starts. It only gets louder the faster I go. I even added silicone at the corners where the door meets the top to fill in the small gaps.
Looking for that quiet ride while cruising. plus it drives my wife nuts!
SHX669
My whistling quiets when i add a shim between the wingwindow latch and the wingwindow frame. -- Makes it shut tighter .
I've also noticed it's quieter when i have the air vent slightly open .
SHX
phred
Earth
I don't think you will ever make the wind noise stop completely. Too many angles and not enough curves on an EB. If you have all new rubber, the doors are properly aligned with even gaps and the windows are sealed well then the wing windows are most likely the problem. I don't use my wing windows because is in the way so they are glued shut. (No air or water leaks).
My 78 bronco however has all new rubber and the wing windows howl at highway speeds. I working on a fix for that with a different shaped seal for those windows.
I'd try a shim on the latch like SHX669 suggested and I bet you'll be set.
Tasty Geezer
Tasty Geezer
robofig: lol...I could use a 100W amp....that would definetely help in the summer months when the top is off!
Otherwise the doors seem straight and alligned. might have to put the wife to work crawling around the cab listening where the whistling is coming from..haha
zeeman1
Seattle
Usually the wing window. I used electrical tape around the seal so I could open it up if I wanted to. Either glue it shut or get a new gasket for it.
ep67bro
Bronco Junky
Easton, MD
I had the same thing happen to me after I rebuilt my 67 all new weather striping and it still whistiled. The wing window was the cause. But as some one else said the Bronco is as areo dynamic as a brick so there will always be some wind noise!
treihesse
I cant hear anything when I drive my truck. I need a really loud radio I think...Wind to a Bronco is like oil to a engine. I dont think my truck would run with out either LOL
crankman
wow thats funny its a box so its going to be a bit noisy its part of the charm i dont think i would even try on mine, just put the pedal on the flowmasters and let er rip.;D
Project_bronco
Cottonwood, CA
What helped me was getting my doors aligned. now they don't leak either. The wind noise only really gets to me once I reach 70 and there is a cross wind. Not only that, but she doesn't like strong winds and tends to get a little squirley...
Anyway, I would definitely suggest door alignment if you haven't already. I used to be able to see daylight through mine.
Tasty Geezer
Tasty Geezer
Thanks guys...feel as though my windows/doors are alligned properly...looks like i'm getting new amp for the stereo
matt w
Personally I like the sound!
...Reminds me of being a little kid! Seems all the cars did that!
..........Well at least the ones we owned! heh-heh ;D
