Windshield Chrome AMEN
g8rb8t
Not sure difficulty level but will take a different gasket than what you have if you don't have trim today.
spap
X2 on the lube it up part, still a pain cause you don't want to bend it
frankentruck70
Cheyenne, wy.
Put the windshield in the rubber, then the chrome. Then place 2 strong pieces of cord in the groove. You can tape the cord in several places with masking tape. Place the windshield in the bottom of frame and push all the way to one side. I lube the rubber with a dish soap and water solution. start with one side and pull cords slowly and rubber will set itself around frame. work both sides back and forth and finish with top. Add soapy water as needed, then just cleanup with rag.
gray gables
so it's easier to get in when the window is out, then try and get everything in in one shot?
coachbarnes
Franktown/Breck, CO
It's not even possible to do with the window in. It's a completely different rubber gasket. The chrome has an L shaped lip that fits into the slot on the gasket. That's what holds the chrome in the rubber. Put the chrome in the gasket, the gasket around the glass, then the assembly goes back into the hole in the top.
Broncitis
MEB Founder
dish soap and water is my choice since it does not leave a residue like a grease or silicone. We try to avoid any silicone products when we can since they wreck havoc in the paint shop with fish eyes when they contaminate surfaces that are going to be painted.
Dish soap and water provides plenty of lube and then will dry and help retain them.
