- Aug 27, 2001
- 5,147
I am about to re-attach my windshield frame and hinge. When I took the original hinge off of the body via spot welds...it looked like a sealer had maybe been put down in between the mounting area on the cowl and the lower part of the hinge to prevent water from getting between that area. The frame has never been off before, so it is a factory sealer, kinda white/ off white in color and looks like a small bead was possibly put down in the center of the spot weld area(center of the hinge)and runs the entire length of the cowl from left to right or vise-versa. Anyway..Is there something else I can put in this same area to prevent water and moisture from getting under the bottom part of this hinge? Let me know what you think.
Thanks,
Blue71
Thanks,
Blue71
