Windshield and Window frame gap(s) - See pics
trailerjack
Central Texas
So I am finishing up some body work and figured I should put the window frames in ('68 doors) and make sure it looks ok. Boy am I glad I checked before painting.
Any advice on how to remedy this? The windshield frame appears seated well, door gaps are good enough for me and I dont want to start messing around with body mounts unless I really have too... Thanks in advance.
73azbronco
shim front body mounts to raise front maybe? How does body line down side skirt look, straight? pic 3332 looks like front end is sagging compared to back
trailerjack
trailerjack
Central Texas
Ill get some pics in the am down the side. As far as broncos go, its pretty straight down the side, especially everything this one has been through (pulled out of the mud in Louisiana reportedly)
Oldtimer
Jr. Member with Sr. moments
Sunnyvale, CA
Pictures, straight on from the side, showing door gap alignment to center of windshield hinge pivot pin.
Pops68
Bronco Rookie
Bazetta Township
Gotta hard top going on it?? That should give you a better idea of how the windshield angle should be lining up, right??
Just spitballin'
blade
Maker of sharp things
Santa Fe
I agree. Even the gaps on the latch side of the doors look larger on the top side. Could just be the pictures, straight on shots would help.
What kind of bodywork were you doing?
You didn’t happen to change the A-pillars by any chance, did you? That’s the critical dimension here.
If they’re original, then your gap between the lower part of the windshield frame, and the lower part of the door window frame should not be that close. Looks from here that they are almost touching and that pushing the windshield top back back will create even bigger interference.
Have you rolled the window up yet to make sure that your door window frame is square and located far enough to the rear?
Are these doors also original to your truck?
trailerjack
trailerjack
Central Texas
Hey Paul, the A Piller’s were not changed out thankfully. The doors, fenders are all new.
Can you elaborate on what you mean by the lower part of the door window frame?
trailerjack
trailerjack
Central Texas
Hey guys, thanks so much for the input. Here are some more pictures. The body was super funky on this one from the get-go, so hopefully a little more tweaking, and honestly, at least the gaps are roughly, the same on both sides!
blade
Santa Fe
If i understand you first post correctly your window frames are bolted in? If they are, is there any adjustment on the back side of the frame that would allow you to tip the whole frame forward?
Glad you didn’t change the pillars. That gives you a head start.
What I meant was that, at least from the pictures, it looked like your window frame was almost touching the windshield frame down at the bottom. At the bottom of the V shape.
If that was the case, then tilting the windshield frame back farther to match the angle of the door frame would seemingly put the lower portion in contact.
Maybe I’m wrong, and it’s just the angle of the pictures, but I wanted to bring it up.
Since you didn’t take the pillars apart, the first thing I would do would be to measure the door openings. In your case that would be from the back of the fender to the front of the rear quarter panel/B pillar.
They must be square. Same for the doors.
They must have the same measurement top to bottom. If they don’t, start there. Possibly with shims under the body mounts.
Unfortunately, it does look like your left to right gaps are not the same, so you may have to shim the mounts differently per side.
Which is what Ford did anyway.
trailerjack
trailerjack
Central Texas
A little tweaking here and there and it is looking better, still need to ship the mount under the passenger floor pan and I think we will be good!
Raltn
Santa Monica
It's hard to tell from the pictures but it looks like you have a rubber seal (or some kind) under the bottom hinge to cowl and nothing in-between the hinges. Others can chime in but I believe the bottom part of the hinge sits flush to the cowl (maybe some seam seal to prevent water) and the rubber seal goes inside the hinge. I'f I'm wrong, please say so so I can fix my build. Best. R
57baja
I was noticing the same thing
57baja
Is that the factory windshield frame? I just replaced mine and my piano hinge was sticking out more towards the hood than yours. Spacing the windshield frame more towards the hood would make that gap go away
I could be wrong, but in the earlier pictures, I thought it looked like the hinge was welded to the cowl.
