Windshield frame to dash bolts not lining up
sterry
Newbie
Tomball, TX
Hello all,
Wondering if anyone has run into this…. New cowl parts and new windshield frame…. Lined up great left to right. Angle looks good. Problem is, the bolt that would go it though the dash to the windshield frame doesn’t line up at all. The hole/nut in the frame is too high. I’m attaching a few picks. Anyone got any ideas???
DC_Gearhead
Your windshield frame looks to be right. You probably should just adjust the hole a little. Below is a pic from mine. Disregard my uneven door gap. Haha.
S
sterry
Newbie
Tomball, TX
Thanks for your replies!!! Not sure I have enough room to slot it up enough without going through the top of the brace material, but now that I think about it, I don’t guess we’re really trying to hold anything down…. Just stabilizing front to back…
Galt72
Newbie
Based on my factory setup your hinge is mounted wrong. the round portion of my hinge is mounted outside of the cowl and hood. "Not sandwiched between"
the gap is much smaller because of this. Sorry hope this helps
serial car restorer
Western Oregon
This is true, I failed to notice that. The original windshield frame and cowl (very rusty) on my '69 had the hinge protruding, and I installed the new parts to match that. If both holes in the frame are high like the one pictured, moving the hinge forward a bit might be enough. Of course, if you welded the hinge down like I did, that will be a big pain.
S
sterry
Newbie
Tomball, TX
Yeah, I definitely noticed that in my setup, but the hinge came preassembled to the windshield frame. Not sure if there is anything I can do with it... Anything easy that is. But I'll take a look at the frame side attach points when I get home and see how it is done...
Galt72
Newbie
That's terrible that they assembled it that way. Can you send it back or take it back for another ? Mines even farther out than the black one up above. Mine has
the round part snugged up to the outside of windshield frame but no part of the round hinge is under the windshield frame.
