Labbster
- Nov 19, 2003
- 755
I put the gasket in the hinge while it is off the Bronco to look at it before I begin to bolt and/or weld it on. I can't figure out what exactly the gasket will be doing? It is too narrow to keep all the water out! It will still seep through the hinge and the ends of the hinge.
If I bolt the hing down to the cowl, do I drill the bolt holes to where I will need to cut a full circle in the rubber gasket or do I bolt them down closer to the hinge so the rubber does not come in contact with them? Nothing makes sense to me the way this was engineered.
2Bad - I saw how you ended up makin your own gasket! This may make the most sense to cover the entire hinge as well as the bolts.....any other thoughts?
