Windshield Hinge Gasket
Labbster
I put the gasket in the hinge while it is off the Bronco to look at it before I begin to bolt and/or weld it on. I can't figure out what exactly the gasket will be doing? It is too narrow to keep all the water out! It will still seep through the hinge and the ends of the hinge.
If I bolt the hing down to the cowl, do I drill the bolt holes to where I will need to cut a full circle in the rubber gasket or do I bolt them down closer to the hinge so the rubber does not come in contact with them? Nothing makes sense to me the way this was engineered.
2Bad - I saw how you ended up makin your own gasket! This may make the most sense to cover the entire hinge as well as the bolts.....any other thoughts?
ken75ranger
Troy, NY
I didn't like the factory gasket either. I put the gasket in and filled the slot with silicone and let the excess squeeze out. Then I had the trim the excess when it hardened.
SeaBiscuit68
Tacoma Wa
Here's my thoughts. Let's say you choose to bolt it down. I would look at the gasket that goes inside the hinge as a cushion rather than a gasket. If it doesn't have holes, make them. Lay a bead of rtv beneath the bolt heads. That would keep the threads dry. The gasket that goes beneath the hinge will need holes as well. That one should repell water well as it gets compressed pretty good. You still need to pass the hurdle of something to bolt to, like maybe nutserts or something. Then you'll need the bolts themselves. You can't just go to Ace and get 'em. Maybe make your own. Good luck with this. I just think they all should be bolted.
Labbster
Labbster
I have the nutserts and bolts from Kentrol, so I think I'm on the right track there. I just can't see a good way to keep the water out. I really don't care too much, everthing on the Bronco is fiberglass except for the cowl, windshield frame and grill. The windshield frame hinge is stainless, so it should last me a lifetime. I just think the design of the hinge and seals are terrible.
The good news is that if the frame or cowl rust out, I can unbolt everything and replace!
